Blx200 led and no throttle need helpplz
Yeah nothing changed
Double check your transmitter and make sure the throttle trim is not cranked one way or the other (by accident), but should be in the middle/neutral..
Then turn it On ,then turn on your rig.
Okay.
Does the ESC fan spin up at least?
Is the receiver coming on? If 'No', ignore all the transmitter solutions provided above. They are helpful if at least something happens.
No sign of life can only come from the main battery connection. My bet would be on a bad solder connection in the connector, ESC barely go dead on power on.
Next, check your RX to ESC connection. Any broken wire?
Doubt that's it, but better check twice.
