Iirc most guys hit a limit around 100mph or so.
Are you bashing it, speed runs or a combo of both?
For just bashing or a little bit of both Turnigy HD 5000mAh 3s.
For speed runs look at the Turnigy Graphene Panthers.
Then Panthers will be your best bet.Thanks for werry fast answer
my plan is only to do speed runs...
You will maybe come close or just a mph over by all other accounts. The highest I’ve seen reported officially was 97mph but there’s a chance someone with more skill and better lipos could push that. I’m curious myself. I hope you do pop 100 first pass. But it would also surprise me at the same time.So with my front wings trimmed, my back wing "flat", using my MMX8S and 2050KV motor, with some "100C" 8000mAh SMC packs, I should be able to break 100MPH if I can find a long enough road?
Can’t wait for the results ????I would expect to have all my new parts installed by the time we thaw out and get dry enough to run it. I scouted one of my Google Maps finds, and I'll have 2500' of smooth, flat bike path to use. I'll be in the center of it, up on my 8' ladder so I can see far enough to be safe.....
Anything can be connected to anything else if you can solder
