chilly81
- Fireteam
- Granite
- Typhon 3s
Also, the balance current limit is split across the parallel batteries. So you might have 25 A worth of bulk, charging power, it’s unlikely you have more than 1.5 A of balance in current per channel. So the balance phase will take longer than it would for an individual battery. For me typically charging two big packs like 6S 5000mah the balanced phase still only takes a couple minutes at most for healthy batteries though. But that time it is twice as long as it would be for just one of those two batteries.they balance the same way one battery balances... all the batteries balance leads connect to the board in parallel so the charger balances them simultaneously. the charger doesn't know you are charging batteries in parallel and the other batteries don't know they are connected together.
