- Notorious
- Talion
- Typhon 6s
I bought a new Max6 recently to replace another Max6 that was hitting thermal shutdown because the capacitors were overheating. I had run a ton of 6s packs through that one and thought it might be time to replace.
No thermal shutdown issues on the new one, but the cap temps are still way higher than anything else.
Running a Hobbystar 4082 1780kv now, 20/46 gearing and belted Jetko Supersonic tires that are 5.1 inches tall, so not geared up high. Also Im not bashing all that hard because of the caps running hot. Bearings are all new and everything feels normal when I try to find binding.
Outside temps were in the 40s at the end of a 6s pack. Motor and esc temps were 90-100, the caps were around 140.
What else should I be checking?
