I have just gone out to bash twice and both times all the oil dissipated out of the diff! It leaked onto the surrounding area does anyone know why? I am using the aluminum center diff case too.
It has a crack in it.. not good?
It has a crack, but it is still able to sit properly against the diff.Gasket
Ugh, I was just there yesterday thanks!Just buy a new 1
I put the new gasket on and oil is still leaking out.Just buy a new 1
Right around the 50t gearCan you locate where it is leaking? Crack in case or possible o ring at this point
that sounds like the gasket. Was it clean and flat?Right around the 50t gear
brand new yes.that sounds like the gasket. Was it clean and flat?
The housing itself. Most times around thread holes there will be tiny plastic parts sticking up that can cause issues. Worse case. A new housing might be in order.brand new yes.
New housing as in diff case?The housing itself. Most times around thread holes there will be tiny plastic parts sticking up that can cause issues. Worse case. A new housing might be in order.
So what you are saying is, keep like 10 complete diffs on hand at all times?I find most plastic parts as consumables. Diff cups are one thing you should count on stocking. Gaskets too. Diff housings as well. A-arms... well you get the point.
Depends on how hard you wana bashSo what you are saying is, keep like 10 complete diffs on hand at all times?
I know you have AT LEAST that many. I keep enough to have probably four or five complete diffs.So what you are saying is, keep like 10 complete diffs on hand at all times?
Yeah since switching to exb diffs. I haven't had to use them. Probably time to sell them offI know you have AT LEAST that many. I keep enough to have probably four or five complete diffs.
