- Bonney Lake, WA
- Granite
- Infraction
- Kraton 8S
- Senton 6s
- Typhon 3s
Blew my center diff, replace with stock or should I replace with something stronger? Links? And what fluid to run?
V2, and I was definitely using handbrake under power ?? It was fun while it lasted. But the whole diff case blew, like a hole in it. I just wanted to see if there was any upgrades out there since I was going to replace it anyways.Infraction V1 or V2 and if it’s a V2, were you using the handbrake under power - because that’s a sure way to blow the diff.
Also, what blew? Stripped gears, broken pins, cracked diff case?
