Heres what i did.due to me having not too much money to spend, and I like to see diys, has anyone tried to make their own diy chassis brace for the 1/8 line?
is the diy top chassis part cnc? cause I don't think I can make that precise cuts haha, I do want to make on when my kraton arrivesThe first photo is a Kraton chassis cut down for a bash/chassis stiffener,second photo is Diy 2inch 1/8aluminum flat bar from Ace hardware.
looks pretty cool and very neat for a diy! Does your roll cage still bolt on even after that is installed? If not, I might have to look into making one where the roll cage will still fit on the chassis, I seen some people use a stick (pole like) aluminum going right in the middle of the roll cageMade by dremmel,file and 4inch thin cutoff wheel,all done by hand and not so perfect!
Just finished and tested mine today, so far so good.looks pretty cool and very neat for a diy! Does your roll cage still bolt on even after that is installed? If not, I might have to look into making one where the roll cage will still fit on the chassis, I seen some people use a stick (pole like) aluminum going right in the middle of the roll cage
The flex yes because it is an issue that people have that tear up the body from jumps and what notWhat are we trying to prevent with home made chassis brace. I presume flex,but more reasoning please. Because you crash jump?
Steve I'm not overly concerned with sparing my Kraton body. If you jump your rigs high enough/bash rough style....Etc there's a real possibility of the stock chassis support system failing. They normally fail in the rear from what I've seen/heard. When they fail, your chassis and shock tower can tweak, bulkhead break, possible damage to at least rear diff gears and center driveshaft. I've already bashed the crap out of my Kraton without it and been OK. But to me it's a matter of time as I like doing motocross size jumps. Don't feel like this mod is a must do. If I don't like any adverse changes to handling caused from lack of chassis flex, mine will either get modified or be removed. Until then it's insurance in avoiding an epic fail. GKA chassis braces look really nice, too. Wanted to try tower to tower first. So far I'm really liking it.What are we trying to prevent with home made chassis brace. I presume flex,but more reasoning please. Because you crash jump?
I like the chassis brace you fabbed up. There are a few others I've seen do the same mod in a similar way, 72Z15SS used graphite.
I have some 1/2" thick walled aluminum rod and some 7 & 8 mm graphite rods as well that I have been playing around with, haven't decided which I'm going to use yet? I can't seem to get a good alignment through the body support tower with the different height in the front and rear shock towers.
I can't tell from your pics, but did you cut any of the cross supports in the center tower to allow for better alignment to fasten the bar at each of the towers without putting pressure on one end or the other?
