Besides my mishap from last weekend, how often do the chassis bend?
This ^ but the swb chassis is less prone to bending vs the long and XL wheelbase chassis.As Often as one wrecks , big..
Stuff will happen, and you will get a chassis bend....Besides my mishap from last weekend, how often do the chassis bend?
True dat.This ^ but the swb chassis is less prone to bending vs the long and XL wheelbase chassis.
I have one arriving tomorrow from JennysRC. Along with a list of other parts that were bent.True dat.
Quite hard to bend a SWB Arrma chassis. Short of abuse. User error there for sure. As you drive better, you should bend them less frequently if at all. Never ever bent My TLRT or Notorious SWB chassis. Especially the V5 RTR SWB chassis, they were designed stronger at the rear where they would usually bend and twist first.
Are you running Alloy Upgrade FF and RR braces. The plastic stockers only contribute to folding a chassis. Also the Typhon doesn't have any T2T brace FWIW. Get alloy F and R braces. Hammer your chassis straight if possible. It will never be perfectly straight again. But may be good enough. Or go to JennysRC to buy another. Your call.
>>>My best recommendation is to replace with the TLRT 7075 alloy SWB Typhon Chassis from JennysRC.
My og Outcast chassis I had so long that the droop screws started to poke through the ears lolTrue dat.
>>>My best recommendation is to replace with the TLRT 7075 alloy SWB Typhon Chassis from JennysRC. If speaking of your 6s Typhon.
The price is right. And buy some alloy braces while you rebuild it. I run EXB F/R braces on my TLRT Typhon. HR or M2C are good as well. If you are still bending the chassis after using these parts , better rethink how you are driving your Typhon. I run mine only with 4s packs. 6s seems way overpowered for this light 1/8 buggy. IMHO. Tried 6s several times. 4s is best for me.
https://jennysrc.com/collections/ar...s-black-aluminum-short-wheel-base-swb-ara8306
My Kraton EXB chassis look like a 2x4 you pull out of the bargain bin.my kraton v5 chassis has taken a beating its got dints in it no black paint left on it at all. and ever so slightly bent
Thank you, this helps.True dat.
