Lazy Bushman
I have the same chargers as you @Revomikey and then I bout the D400 Duo from Skyrc and been pretty happy with it
I have that charger as well in my car. It's an OK charger, but there are quite a few that have issues. Mine, on one channel, I can't decrease as the increase button doesn't work. I fiddled with it for an hour and somehow, it reset and works again. Not sure I'd want to rely on it as my only charger.
I have the hitec D7 in the house, it will do 2x200/2x20A on AC or DC. It's pretty pricey to buy, I won it used on ebay for $135.
In other charger threads, this one came up:
https://www.smc-racing.net/index.php?route=product/product&path=113&product_id=530
Since you have a good PSU, might want to just get one of those. Might want to read the manual though and make sure it puts out enough watts/amps for your needs on the voltage your PSU supplies. For $110, it would have been perfect in my car on 12VDC for what I do.
For another 50 bucks you could triple the power. Just sayin'. Nothing like turning around 6 batteries in 30 minutes.
qty 2 hp server power supplies, $40 on ebay
isdt T6 charger, $75
That'll get you 600 watts, and the power supplies are good for plenty more if you ever wanted to add another T6 or maybe a different isdt charger.
I have one huge power supply that will run these
Guessing you have some pretty good lipo's. Not many of the cheaper ones like being pushed beyond 2C on charging. SMC recommends 1C. 5000mah in 15 minutes... just did the math, think 5000mah in 15 minutes is 1.25C, so not too bad. Just sounds harsh I guess. LOL!I’ve looked at the reactor chargers a few times, let us know hoe you get on with them,
I’ve got a 1150watt 25v psu, can’t think what make charger now, will have a look later but I can charge a 4s 5000mah at 10amp in about 15 minutes
Yeah... spent 2.5 hours out bashing in the snow yesterday, can barely stand up today. All the unsure footing and standing with boots that I think are too small on nearly killed me.No worries m8. I often screw it up with nothing going on. Getting old sucks, lol.
Actually, I emailed Danny at smc, he recommended 2c-5c charge rated. Also, seems the paper that came with my 'true spec' packs listed 2c charge rate.Guessing you have some pretty good lipo's. Not many of the cheaper ones like being pushed beyond 2C on charging. SMC recommends 1C. 5000mah in 15 minutes... just did the math, think 5000mah in 15 minutes is 1.25C, so not too bad. Just sounds harsh I guess. LOL!
