Granite Chopped Granite
I love the wing, that's exactly what the granite needs, can i ask how and what you used?
It’s my extra Typhon 3S wing. The rear body mount for the Granite still works, but you can’t get screws into the diff case and it sits a little higher. I also lowered the front body mounts to their lowest position. I also had to cut out the tailgate section and make a notch in the front. But my tail section was already pretty abused from running it without a wing. I also have a red body from my Mega as well but didn’t cut that one yet.
Typhon wheels are good. ?
These trucks you guys have here look excellent. I can't believe I missed this thread moving again.
I tried the Typhon shoes for a couple goes too.
43030
I need a spec sheet on this build!
What wheel adapters? Those MX28s?
I want to do this exact thing to mine, but with a F100 Proline body. The wing will help save the tail-gate!
I’m using HR 17mm x 10mm offset hex adapters with Badlands MX28 wheels and tires. The wing is from a Typhon 3S. Had thought about stretching it out with a LWB chassis until I snapped my Typhon chassis and had to use the chassis in mind to fix the Typhon. Still might grab a LWB from JRC.
Still on the Duratrax 14 to 12mm here. Then Hot Racing 12mm to 17mm with 6mm offset / extended on each side.
I like the setup and doing it exactly again on the Granite I just got in classifieds. There's a second set of Hot Racing WH17HS01 that I was gifted for Christmas still unopened. ?
I usually run badlands.
https://photos.app.goo.gl/3TMPqtuoTaxZ4kex9
Yup... all these are awesome... and now I blame @jondilly1974 for the inspiration.
I did take the stickers off though... haha.
