So, how can I do it? I need to wait for the Arrma warranty right now. I think the slipper is too tight.You can but it will pop back out very easily
Yeah chances are the slipper is too tight or landing on throttle will do it. I always just had to fight mine in. They make a tool for it but I would just jam it in there. They are fairly cheap on Jenny's. I would just pick up a set because chances are it is going to happen a few times honestly.So, how can I do it? I need to wait for the Arrma warranty right now. I think the slipper is too tight.
Also, the car isn’t even a day old yet.
I ran it after popping it back in and it was fine.You can put it back together but it is already damaged and will keep happening over and over again. Best bet is to replace them. Very cheap from JennysRC.
u asked and we are telling you. U may wanna get some on the way. We promise. All of us. Get driveshafts. Soon. Probably. Before u "have to". Why not? Go ahead.I ran it after popping it back in and it was fine.
Loosen the clutch half a turn It popped out for a reason the clutch is the reason number 1I ran it after popping it back in and it was fine.
It won't last long. Trust me.I ran it after popping it back in and it was fine.
I loosened it after I popped it back in and it the Granite has been fine! Backflips and wheelies for days!If it popped once only loosen the clutch half a turn more. You might be lucky and wont pop out anymore. Why they pop is because of the clutch being too tight ussualy
Well, it has been fine after running it pretty hard. If it fails, then I will get new driveshafts.It won't last long. Trust me.
Well, it will fail again. Maybe not today, or tomorrow. Might even last a month or three but sooner or later it will fail again. We've all been thru this already. Once it comes apart it is never the same again. It will come apart again, eventually. Good luck bud.Well, it has been fine after running it pretty hard. If it fails, then I will get new driveshafts.
