Tex Koder
2D , 3D Not a problem. I'll take that Challenge.
ArrmaForum Fan
Hospitality Award
- Dallas, TX (USA)
- Granite
- Infraction
- Kraton 6s
- Mojave
- Nero
- Senton 3s
- Typhon 6s
- Vendetta
- Thread starter
- #21
I thought you must have had the outer screw holes on the fan plate going through into the motor brackets?
Because of different lengths of 40xx cans and how different chassis and other accessories that could be in the way, those brackets (MAY) not line up with those screw holes on the Fan Plate -to be used as securing points in every vehicle setup...
If you look closely, I made the Fan Plates' "securing rails" the entire length of the plate, so you can slide the brackets to where ever you need to "clear obstacles" -either on your motor itself (cables, screws, built-in ribs for cooling etc) or things around the chassis near the motor.
Which means that those brackets may not even be where it needs to be aligned with those screws...
