Kraton Damaged Outdrives
Pepijj221
While removing the motor from its place a saw the damaged outdrives shaft things..
Anyone know the cause of this? And solution?
Just running 14t. stock diff.
Anyone know if and then what team durango diff outdrives part nr i can replace cause the arrma outdrives (ar310439) are out of stock everywhere around in swe and i don't wanna go ebay :)
While removing the motor from its place a saw the damaged outdrives things..
This is caused by hard throttling. Full trigger from dead stops and on/off full trigger. The out drives are known for being soft and the hard throttling eats them up. One way to reduces this is to spray them with some kind of lubricant other than wd40. WD40 is water based and causes more damage than good. I spray mine down after each bashing session with PB blaster, it's a lubricant and prevents rust. You will need to replace these and you can search the forums on how to harden them. Some use water for this and others use oil, the oil seems to be the best way because it cools slower making the metal stronger. Good luck with it.
Thanks for the helpful information!
Or is this what I need to buy will it work for the front and back dog bone cups
I bought the complete diff on dollarhobbyz for pretty cheap. Only didn't use the Mugen cup and outer gear.
No idea about v4. I went for the aluminum HR cups for replacement. Check part diagram between older and v4
