- Illinois
- Fireteam
- Infraction
- Limitless
- Kraton EXB
- Talion
- Typhon 6s
- Typhon TLR
Me either, mine are all stock as well. I literally only have three runs on the rig, each ending with varying levels of carnage. The last one was terrible and ridiculously expensive. It’s been on a shelf since, but it looks like I might actually get back to the bench in a week or two and that Losi is near the top of my priorities. Let’s say top 5…Pretty sure mine are all stock. I never changed the diff fluid after I bought it. The center diff seems seriously light, I plan to try 20 mil or something eventually.
I'm still salty my rear bulkhead bearings exploded when I landed a jump on all fours. It always sucks when you land a jump and still end up cutting your run short from damage lol. I was warned I would need to get alu bulkheads asap though and already had some in the bin waiting to go.Me either, mine are all stock as well. I literally only have three runs on the rig, each ending with varying levels of carnage. The last one was terrible and ridiculously expensive. It’s been on a shelf since, but it looks like I might actually get back to the bench in a week or two and that Losi is near the top of my priorities. Let’s say top 5…
I got Vitavon hubs and bulkheads to install. Going back with factory a-arms. I already got the steering bellcrank, center braces, towers, and top plate. So I totally did it bass-ackwards.I'm still salty my rear bulkhead bearings exploded when I landed a jump on all fours. It always sucks when you land a jump and still end up cutting your run short from damage lol. I was warned I would need to get alu bulkheads asap though and already had some in the bin waiting to go.
I've now had 2 different xlx2 die in my dbxl though and I don't know why. Did you wreck yours jumping? everyone always says not to jump the dbxl much but I bought it fully expecting to jump it the same as all my other rigs so I'm hoping my next time taking it out It can survive since I believe I have almost all the weak spots addressed. I heard alu knuckles/hub carriers? were a needed upgrade too so I also have them in the bin but haven't broken the stock ones yet.
How's the fit and finish of that GTB stuff??? Thanks Mikehttps://www.ebay.com/itm/314035373870
I got the whole kit option.
https://www.ebay.com/itm/194959361004
I believe I did f500k c1m r200k on the max4 dbxl-e, 24t pinion stock spur. It definitely needs a little thicker up front... as it can and will balloon the mx43's right off without throttle control... that one also has the vitavon f/c/r bulkheads $$$ but highly recommended!!!, all stock suspension stuff except hub extensions, and full losi aluminum chassis braces.
That diff case link, does that come with both front and rear or is that saying it fits front or rear?https://www.ebay.com/itm/314035373870
it comes with both, i would have been mad af paying 130$ for one bulkheadJust got mine all ordered up so I'm happy to see some other info on it I got a slider off eBay because I knew electronics and tires were different off the jump. Have the max 4 combo to go in and mx43. I'm really pumped to dig into it.
Lolol that's what I was thinking tooit comes with both, i would have been mad af paying 130$ for one bulkhead
I find that if you have a somewhat fragile rig , you should be running thinner Diff oils in general. It will only help better IMHO.I believe I did f500k c1m r200k on the max4 dbxl-e, 24t pinion stock spur. It definitely needs a little thicker up front... as it can and will balloon the mx43's right off without throttle control... that one also has the vitavon f/c/r bulkheads $$$ but highly recommended!!!, all stock suspension stuff except hub extensions, and full losi aluminum chassis braces.
