Hello all,
So I bought a custom Kraton with a HPI Flux 2200kv, MAX8 esc, dBoots Backflips, and a "high speed pinion gear". It ran great for 2 packs, but then I realized my temps were 180+ because I was running offroad and like to learn lessons the hard way. Turns out the only way the HPI motor fits(3mm heatsinks all the way around) is with the motor mount slid all the way out, hence the "high speed pinion gear". So, bought a new motor(EZrun 2200) and all the Hot Racing aluminum parts that go inside the chassis.
During installation of the new HR parts, the Fast Eddy bearing would not press into the HR channel lock motor mount without extreme force, is that normal??
I ended up using a pliers to press the stock bearing, which was still attached to the center diff, into the HR motor mount.
I go out and run it and now it's slower than my daughters brushed 1/16. Seriously, does about 10mph. Better yet, it now leaks diff fluid from center diff cup.
Silver lining is my motor temps on that run never went above 100F, and when I took the center diff out, the truck rolls great so I think I know where my problem is.
My plan tentative to feedback is:
Build a new center diff with HR diff cup, mugen shims, all new internals, 200k fluid
Install 16T pinion gear from Tekno
My questions are:
Do I ream the inside of the HR motor mount where the bearing sits or press it in? How tight is too tight?
When shimming the center diff, is it the same as doing front/rear diffs?
Will a 16T be OK for bashing on both 4s and 6s?
Should I just buy a new Kraton?
Really appreciate any input here as I've only been into RCs for a couple months!
My questions are:
