- ST.LOUIS
- BigRock 4x4
- Mojave
- Notorious
- Senton 6s
- Senton 3s
- Typhon 6s
I've been a foam technician for 9years(drive,maintain, matenence,prep,spray foam insulation an spray rig.today I had a problem with hose heat..300 feet of hose that's heated to 130-140degrees to make foam.hi-pressure,hi- temperature system..hose is in 50ft sections an has 6 Aug wire running from machine to spray gun an back to machine..a big loop.anyway.i tore apart hose till I found break in wire..had happened many times over the years.grabbed some connectors an fixing....
How would these work on high-volt speedruns????know a little about electric,I know it'll hurt ya without ya seeing it coming...still researching them..anyone a Electrician or knows if these would be worth giving a try on my high voltage car.
