Typhon Difference between senton and typhon?
Daja Duke
Can anyone tell me what the differene is between a typhon and a senton besides the body and post configuration. IE... are the A arms, Axles and wheel hubs the same? Curious if you can inexpensively put a senton body on the typhon.
On the Typhon the arms and driveshaft are longer. Also towers and shocks are different. Senton have no wing, but front/rear/side bumpers and also a roll cage.
Thank you, do you know approximately how much longer the total length is on the typhon arms is? I was intrested in using a proline sc fusion body on a typhon if possible.
Total width difference is about 10mm, meaning tires will touch the wheel arches, Typhon tires are also bigger, so expect even more rubbing.
To support the bigger body, the Senton body mounts are much wider, also the bumpers hold the body much better, without all this I wouldn't expect that proline body to hold for long on a Typhon.
