22-250Fan
I checked my front and rear diffs today for the first time. HINT!!! If you buy a new rc, check the oil in the diffs before you run it. When I opened the front on my BRCC, it looked like at assembly, they smeared a blob of grease about the size of a dime in the housing. Nothing touching the gears at all. The rear didn't have anything in it. Is this usual or did I get "Lucky"? The ring gear on the rear doesn't look in the best of shape but it'll work. The front had a little grease on the ring gear and looks like new.
My question is should I put diff oil or grease back in it. I'm going to start with 10k weight grease or oil to start with.
