Josh nortz
I have not had a lot of trouble with shafts just ends. kraton caps will thread on but need some diffrent balls to mount them with... I have a set just have not gotten around to putting them on.
Mine haven't come off yet either but I just see them becoming an issue since I have upgraded the rod ends and put on the aluminum rockers. Somethings gotta give in a bad event and I just hate when it's the shock caps on an rc because they're annoying. I just wanna try to focus the failure point to the spot I want. I saw that the Kraton caps fit with some mods but I'm trying to find some that can be aluminum and still have aluminium pivot balls.I have not had a lot of trouble with shafts just ends. kraton caps will thread on but need some diffrent balls to mount them with... I have a set just have not gotten around to putting them on.
Wow those look good. And there are a few adjustable holes for the push rod end to mount.
And they do appear to fix the "binding" issue the OP mentioned.
Wow those look good. And there are a few adjustable holes for the push rod end to mount. I may have to make a purchase sooner rather than later. And they do appear to fix the "binding" issue the OP mentioned. The real question now is how durable are they?
Shipping to germany is also possible $14,50. So should buy two at the same time.
First I put the shocks further inside and test. Original the shocks are mounted at the outside of the 4 possibilitys.
Sure are. I am looking at a new motor so that is coming first as my rockers are not broken. But these are definitely going to happen.. So long as the lady doesn't find out I'm about to drop another possible couple hundred on the Nero... hahaThen we are already two, who have declared themselves ready for the first test
At that point, it's almost not worth your time to design and manufacture your own.
I'm thinking you are breaking the plastic rod ends and not the shafts themselves, but I could be wrong. either way, the rocker arms could be to blame. make sure that the slot in your spring perch is lined up inside the rocker arm as I pictured earlier. it can only help.
Haha, yeah I have dumped tons of $$ into mine also. Thankfully I am at a point that the parts I have replaced I did so with higher quality ones and haven't broken anything in a while minus a spur gear which was my doing in not making sure it was meshed properly. That and motor/ esc combo, but again I didn't do the proper research into that, and its on a whole other thread here so not going into it. Lol.Thank you, I will make sure!
I am already beyond this point. My wife counts the money not at all anymore that I stuck in the hobby.
But I have the problem that I always have two neros that need to be repaired :-(
When I bought them, I thought they would be unbreakable. But after the first ride only the driving mode changed and not the number of broken parts. But it makes a lot of fun )
I agree that having one plate could be better as it would not be in the way and bind. As far as travel we will just have to see how they actually do. Since none of us have them yet, it's all speculation. Lol. Same with durability and any other issues that may or may not arise. But like Havoc said, can't have it all.
I'll let you know more when mine show up
Awwww you ordered some?? Im jealous. Haha. Def keep us updated! I'll prob order some after I order my nee esc/ motor..I'll let you know more when mine show up
