Yeah it’s too hot to play outsideWell I just did a 7min bash in 96f weather and it went thermal . Lol
That esc is going to be for the exb.
Gearing is 34 pinion and 29 spur.
Spektrum pkg 1250kv/160 amp esc. Gearing is 34 pinion and 29 spur. Did the calculation on some rc website and it showed 143mph. Would this esc handle it or do I need to upgrade to a castle?
That shouldn’t matter, it’s got to be something else. Are all your bearings free? Trims are adjusted properly?Maybe is my 29 spool. Who knows ?
I’m running 8s, with punch level 3 and a recent pb of 117mphPunch is set to 1 and still spins out . I think the gearing and power of the motor on 8s is too much torque at any speeds.
Thought it might be something like that, glad you figured it out. ?Well found the problem. Rear drive cup was loose. Forgot to use loctite on the grub screw. The car was rear wheel drive all this time. Lol
