Don't do this, EVER..!!
BashingBrian
#ArrmaAddict #RCwhore
Build Thread Contributor RC Showcase: 3
UK..
  1. Infraction
  2. Mojave
  3. Mojave EXB
  4. Mojave Grom
  5. Talion EXB
  6. Typhon TLR
I only did this to test the car and to make sure it all worked correctly before I remove the motor and esc and some other bits..
I'm going to get told off I know, but I only posted this to show what you should NEVER do..!!!
Have fun with me, I can take the punishment.. ;)
To all of you with connector OCD please look away now..........
If you were taping wires together I might be concerned. I read somewhere that the plugs have less resistance than the wires. You've just improved the efficacy of your system.
I'm with you on that one plug is enough, I still like your solution.
Man I use qs8 to ec5 adapters all the time. Never had a single issue and I will continue to do it :ROFLMAO:
Ia a single adapter like this the issue or is it multiple adapters or is it just frowned upon in general?
I am guilty of using adapters, but I’ve never had an issue.
