Velodromed
Snatching defeat from the jaws of victory!
- Location
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
Is this a 4s issue? Did you snap axles on 3s at all? I’ve hot racing extensions on two cars and m2c with cvds on a third with no issues so far. But I stick with 3s, running 3670, 3050kv motors, 130amp esc with 18t pinions.Any problems with snapping wheel axles? (Not the driveshafts, the axles on the end.) With Hot Racing extenders (and aluminum front steering blocks/rear hubs) I was snapping wheel axles all the time. The less flexible CVD axles snapped even more often. It's why I stopped using the CVD's.
Looks like you're using the M2C extenders. They're very similar in design to the Hot Racing extenders, they have that nut that covers the wheel axle and may help prevent it from snapping. If they do, maybe I can try CVD's again.
