Might as well start one of these threads for my Limitless V2 build. It's going to be awhile before this build comes to fruition but might as well start documenting it.
I picked up the V2 when Horizon had a 10% off sale so it came out to $386.99.
I knew I wanted a big block motor so I also picked up ARA320722, Sliding Motor Mount Plate 56 Series.
So far the progress has been as follows:
After installing the 50-series motor plate, it looks like the smallest pinion that will mesh with the 39T spool is a 38T pinion. With a 37T pinion, the mount is all the way in and the mesh is slightly loose. This was a little higher than I wanted to gear it so we'll see what can be worked out.
Still on the list, a servo and an XLX2.
- Shimmed the front and rear diffs with Mugen E0206 shims
- Replaced the steering bushing with ball bearings
- Replaced the non-adjustable steering tube with Hot Racing AON48A02, Servo Saver Tube with Clamping Nut Set
- Replaced the 23T servo arm with Hot Racing AON48E25, Direct Driver CNC Aluminum Servo Arm 25T
- Replaced the motor mount flanged button head screws with M4x16mm Flanged Socket Head Screws, Part Number 92235A114 from McMaster-Carr
- Installed a Futaba R304SB Receiver
