- Thread starter
- #61
Pretty happy with my current setup. I’m sure it’s a case of ignorance is bliss. Will run with it for a few months and just improve things as I go. Just had a 25 minute street bash and I’m getting more and more comfortable with the car and the controls. Wishing for more track time but the weather is not cooperating! I will try to adjust only one variable at a time so I can structure my learning.
@SrC @Overkill - Actually some of the guys at the track did say, there’s way too much power on this motor (and esc), at least for this track; but we knew that coming in. A better suited setup is the Hobbywing EzRun Max6 combo 1650kV - shaves a lot of weight for sure!
https://amzn.to/3uj9i2f
But for now, just need to go easy and be careful.
I did notice the input shaft cup has a bit of slop to it (~1mm). Is that normal? Any way to reduce it?
@Overkill - If I recall correctly the session times were supposed to be ten minutes.
These just arrived today so will finally get some official lap times next time around.
