Hi all I need some help please
I have just received my EXB woot woot
My issue is with the electronics I have purchased.
I used the recommended parts on the site I used which is
EZRUN Brushless Combo.
Ezrun 4274 with the EZRUN Max8
The ESC does not fit at all on the mounting plate as the plate it comes with is not compatible with the whole alignment of theEXB housing plate so can only put one screw in
( n not using 3m tape n one screw) also the start switch can only be mounted with 3m tape as it has no fixing point to affix to the EXB plate
On set up it comes with the 12T pinion but I am lead to believe that this is for the high speed set up so should I go with the 15T pinion as recommended to me.
somewhat confused at mo
My apologies in advance but I’m n old fart noob having a mid life crisis
