- Statesville nc
- BigRock 4x4
- Kraton 6s
- Kraton 4s
- Outcast 6s
- Talion
- Typhon 3s
Can I put a blx120 in my 3s typhon to replace the 100. I only run 3s
YesCan I put a blx120 in my 3s typhon to replace the 100. I only run 3s
Yes. The BLX 120 can run 3S or 4S. But I think you should also upgrade to the 2400kv motor as well if you ever intend on running 4SCan I put a blx120 in my 3s typhon to replace the 100. I only run 3s
Hi
Just to be sure… We can run 2s with BLX 120...?
Thanks
PL
Here is what Arrma says on their website for the BLX120 based 4S Kraton. I will charge up a 2S and give it a try. I’ve never tried it.
I believe we did figure out the BLX120 will not run on 2S. But IIRC, the BLX185 will ??Finally, did you gave a try on 2s batterie?
