- California aka Commiefornia
- Kraton EXB
- Outcast 6s
- Talion
Have an EXB diff taken apart and adding the 13x16mm shim on the outside of the diff ring by the bearing is a bear (Dad joke).
Have some 8x12.7mm shims that fit in between the diff ring and bearing. This should work the same as the 13x16mm shim right? Any cons to this?
Also would adding a shim between the outdrive and bearing have any benefit? Maybe keep the bearing cleaner?
