The pinion should be fine. What about the timing?Pinion is 16T M1, its technically second hand since I got it on a trade for a kraton, I converted the rear gears to GP5 so I can run the same-sized tires on all 4 corners. After breaking it down the RX is from an older unit so it will need to be put back to spec as well.
Esc stinks like burnt plastic and puts off esc thermal error and only steering responds.. Are all 6s escs the same (jennys rc) or is it better to just upgrade at this point?
Touch spot...sorryEsc stinks like burnt plastic and puts off esc thermal error and only steering responds.. Are all 6s escs the same (jennys rc) or is it better to just upgrade at this point?
