Finally bought my V3
Discussion in 'Typhon' started by bluedeval03, Aug 7, 2018.
Tags:
  1. bluedeval03
    bluedeval03 Premium Member!
    Premium Member ArrmaForum Fan
    Jul 21, 2018
    45
    Danville KY
    Hello fellow Phon'ners.... Finally pulled the plug and bought my first Arrma, now the wait for it to get here blues. I have started to order several of the Hot Racing upgrades front/rear braces, fixed link steering w/servo arm, is it necessary, or as I feel it is, since it going to be in bits and pieces go ahead and install the bellcrank set from HR also?
    My intention was to go ahead and swap out the aluminum towers with carbon fiber towers, BUT from what I have been reading, if I do go CF towers, then I need to go ahead and swap out the gearbox/bulkheads with aluminum. Am I thinking correct? or is this all a waste to do on the V3 with the exception of installing the front and rear brace, steering bearings instead of bushings, and upgrade to HR aluminum diff cups??
  2. Nucear
    Nucear Well-Known Member
    Aug 7, 2018
    34
    4
    I would say wait until the aluminium towers brake and if they do get the CF ones.
    Best regards
    Elias.
  3. Jerry-rigged
    Jerry-rigged Premium Member!
    Premium Member ArrmaForum Fan Excellence Award
    Apr 27, 2016
    1,965
    1,087
    Texas, Baby!
    Arrma RC's:
    Kraton, Typhon, 4x4-Mega
    The Typhon is probably the most solid of the BLX6s cars. I vote save your money, unless you just like Bling. In which case, Bling away.
    Voltron7 and bluedeval03 like this.
  4. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    As always, thanks thanks for the advice
  5. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    can a single 5s battery be used or does it have to be either a 2s or 4s config
  6. chevys10zr2003
    chevys10zr2003 Premium Member!
    Aug 29, 2016
    1,102
    421
    Minnesota, USA
    Arrma RC's:
    Kraton, Senton, Typhon
    It can run on 5s but you need to switch it to NIMH mode and you will lose the low voltage cutoff and need to run an external voltage alarm. The ESC can sense 3s, 4s and 6s voltages.
    Voltron7 likes this.
  7. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    thank you for the info
  8. Trillium
    Trillium Well-Known Member
    Nov 7, 2016
    79
    113
    Arrma RC's:
    Typhon
    Ditto, If it aint broke don't fix it! I can understand upgrading parts as they break or strengthening to save cost in the long run (braces/ bumpers etc) but save your money and enjoy the car as is until that point. Pulling out brand new and perfectly working servo's, suspension and motors never made sense to me unless you are a pro and need too.
    bluedeval03 likes this.
  9. Voltron7
    Voltron7 Premium Member!
    Jun 9, 2017
    207
    94
    Maine
    Arrma RC's:
    Typhon
    As others said, probably don't need the towers until the stock ones bend or break. I did do the CF shock towers after one of mine was bent, and have been fine with the stock bulkheads. I don't ever plan to go to the alum bulkheads. Had lots of jumps and crashes, too, I'm not gentle with my Typhon...
    Ditto
    Wow, I think I trashed a perfectly good 5S because I did not know this...Could that info be made a sticky? (Or is it just common knowledge for most surface RC folk?) It ran for about 30-90 seconds and just quit. It was also puffed out.
    bluedeval03 and chevys10zr2003 like this.
  10. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    Thanks again folks. I like having the parts that tend to break on hand. Also is the Mugen 0206 shim kit the only shim set I need? or do I need to purchase a couple of odd balls not in the kit? As for hop ups, I went ahead and ordered HR's front and rear brace, steering set, and diffs. Not a fan of slop in my steering, waiting to see what I need for steering servo, but from what I have gathered so far the Savox 1210 is the way to go.
  11. chevys10zr2003
    Aug 29, 2016
    1,102
    421
    Minnesota, USA
    Arrma RC's:
    It shouldn't have puffed from running it unless you brought the voltage down too low. The reason it ran for that time is because it registers the fully charged 5s battery as a mostly discharged 6s battery. So when you get on the throttle it drops the voltage to low volatge cutoff for a 6s battery.
    I have always seen the Savox 1210 recommended and never realized how large of a performance gap there was between 6.0 volts and 7.4 volts. That is pretty crazy.
  12. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    yep
    https://www.hobbytown.com/sw1210sg-...eel-gear-servo-by-savox-sav-sw-1210sg/p262193
  13. bluedeval03
    Jul 21, 2018
    45
    Danville KY
    is the factory front and rear braces strong enough then? I'm all for not wasting money and that will let me buy other things. I have already placed my order for the SMC 7400mah 4s batteries. Just finalizing other knick knacks at this moment. I haven't seen much mentioned about stock arms not lasting either now that I think about it, so need to get the RPM's on the way?
  14. Voltron7
    Jun 9, 2017
    207
    94
    Maine
    Arrma RC's:
    Typhon
    Interesting, that jives exactly with how it behaved...Puffing-maybe it was just a shitty/defective pack...anyway it's been retired permanently...
    Sorry for HiJacking
    chevys10zr2003 likes this.
  • Welcome to Arrma Forum
  • Disclaimer
