Granite Finally got a parts...my upgrades ?
Mk_Rc
have a nice day arrma maniacs ✌
Europe Slovenia
  3. Typhon 3s
After a month of waiting, a post arrived...I installed the hr pivot balls, hr direct fit adapters 17mm and pro line badlands mx 28.
so far...hr pivot balls are very good to minimize slop, now its more tighten and feel much better than before with stock pivot balls.
http://www.hot-racing.com/index.cgi?partnumber=SCP160B02;c=563
hr direct fit adapters 17mm are nice looking and quality build..they fit perfect and not much slop ?
https://hot-racing.com/?partnumber=ATF117XT02;c=1345
Proline badlands mx28 are cool...great quality and change look of truck to look like a beast i love it ?
https://www.prolineracing.com/tires/badlands-mx28-2-8-all-terrain-tires-mounted-17mm.asp
i wonder why tires wobble..its new but they wobble? when i have installed stock tires they wobble to...bearings are new...my only concern is that the axes are bent...could bi this a problem for it?
Update:
- Rpm arrma typhone 3s arms
- arrma typhon turnbuckles
- t bone racing front bumper
- changing worn slipper pads
- fast eddy bearings
- arrma typhone 6s shocks
- hot racing adjustable motor mount
- robinson racing 18 tooth
I really like the wide stance with rpm typhon 3s arms on the granite...damn this thing is a beast and so much stability provide ?
Typhon 6s shocks just what i expected ( i use 32,5 wt oil but it seems it's slightly too light)
I didnt instail hr adjustable motor mount becouse i did order a wrong 18 tooth pinion its waaaay to small ?
I almost done with my upgrades ?
Im loving your truck looks like a beast. But how much wider does it sit with the typhon arms? I just got a granite and was looking to make her sit wider for a more aggressive driving style. I found these looking in the fourm. but I'm thinking maybe I could go with both and put some beast tires on.
https://hot-racing.com/?partnumber=ATF117XT02;c=1385
Yeah you got the wrong pitch on the pinion too. It needs to be a 32p not 48p
Tnx men ? tomorrow i will measure and post pic...this adapters are great and direct fit. You can put any of 17 hex tires.
Sweet. Really digging the wider stance! ?
What turnbuckles did you go with? I'm kind of excited to get this done myself and have all the other parts in my cart on Amazon. I'm assuming the typhon turnbuckles?
Yep I bought the set from JRC
