jkflow
TB RC Bashers
Hospitality Award
Currently running this stock ESC on my Infraction V2 and experimenting with fans. Didn't have an issue with the stock pinion but like everyone else I want 'more power' on the fans and upgraded mine.
Up until yesterday, I was not really believing the telemetry, which can be displayed on the DX5C or other capable TX.
I was seeing 92C up to 98C (208F) via telemetry while external the ESC was at ~ 135-140F, huge difference. With my fan running, it cools down quickly, but stays fairly steady under load. Below is a screenshot.
I geared down from 19T to 17T and expected temps to go lower, same values but I do not have datalogging to see if there is a change in ramp up time etc.
At any rate, I saw my temps go to 102C and 105C as I was rolling back to check. It literally cut off power to everything when it reached 109C (228F) on the last reading I saw, external was 148'ish. Luckily it was just rolling the last foot. No steering no nothing. Temp cutoff, I guess, but I would have expected a true temp shutdown with steering and not a hard 'off'.
I checked my fans and there was a piece of trimmer line caught in the ESC fan which made it stall i.e. I had zero cooling, easy fix and aded additional screen and yes ESC still runs fine for now.
At any rate, surprised that there is no thermal shutdown other then plain 'off'. No plan on repeating this to verify though.
If you have telemetry TX's, turn it on and use the auto-setup. This is about the only screen I use.
Running today to get a baseline on temps, using the stock pinion, but now I actally believe the telemetry on temps. The RPM is a different story, it seems a bit flaky with spikes into 89000 rpm.
What was surprising is the external temp on the heatsink using a temp gun vs internal reported. Almost a 60F difference.
No ideas how other ESC stack up, this is the first with telemetry. The shutoff makes sense which somewhat validates the reported temp.
