Pls share.thats awesome, how heavy is it? i recently made my first RC ramp, mind if i share? mine doesn't fold but it does have a cool party trick.
ill post it tomorrow.Pls share.
Just 10 kilo = 22 pounds
L39 x w39xh17 inches
Adjustable didnt had the patience anymore so Not at this moment...yetVery cool!
What material did you use for the launch pad/flat part? This winter I am going to attempt to build something very similar to yours. Want it light and portable.
Is the jump angle adjustable?
Great job man! Ramps like this make bashing so much fun as you can basically take the ramp and set up anywhere!
Very cool man. Great job.Adjustable didnt had the patience anymore so Not at this moment...yet
Wanna use the 3 support legs and move them backwards a bit. so just a few more holes to drill in the lowet bars. Or put smaller support legs. But that's extra parts so I'll go for the extra holes
Ramp made of
Aluminium frame small kokers
flexible plastic plate 2mm thick. Plexiglass or something. End used popnales like in the aircraft industry to. ( work in a factory whare we build containers for aircrafts ) to nail the plate on the kokers.
Safety walk strips for antislip
Very cool! Gotta post some vids of it on action. How much it weigh?I made it using wood i had laying around. Made it in 2 sections so i can just use the bottom half so the car goes further and lower or clamp it together if i want height. Put a peice of wood on hinges at the bottom to smooth out the ground to ramp transition. Its surprisingly light weight.
View attachment 249335View attachment 249337View attachment 249338
Bro.... do you have to put a space suit on your $h!t before you launch off that beast?I made it using wood i had laying around. Made it in 2 sections so i can just use the bottom half so the car goes further and lower or clamp it together if i want height. Put a peice of wood on hinges at the bottom to smooth out the ground to ramp transition. Its surprisingly light weight.
Loving your design! You're giving me ideas! I know the temptation of putting the grip tape on the surface, but personally I wouldn't do so. When your rig hits the ramp it will inevitably bottom out & the 1st parts to hit will get abraded down like ya put a belt sander on em. Your tires will have enough traction if you carry enough speed on the approach to the front. If you're accelerating hard or steering hard, for that matter, on the ramp it's too late already, just go around again. Just my opinion tho This has just been my experience w/ jumping, but try not to be hard on throttle when you land either. Tough on equipment- tires, diffs, driveline etc. Here's the 1st one I built, free dumpster buildView attachment 250300
44cm = 17 inch my first fotos
34cm = 13 inch so its adjustable now, I think View attachment 250303
Welded the top bars, not the bottom wanted to keep the flexibility on the ground when adjusting the height.
Test drive tomorrow
.I made it using wood i had laying around. Made it in 2 sections so i can just use the bottom half so the car goes further and lower or clamp it together if i want height. Put a peice of wood on hinges at the bottom to smooth out the ground to ramp transition. Its surprisingly light weight.
I think my ramp is the same size as the front half of his!
Well you have a point on the grip tape. It's allready damaged. But with the backflip just a bit of gas when front tire leave the ramp it does help with a bit of grip.Loving your design! You're giving me ideas! I know the temptation of putting the grip tape on the surface, but personally I wouldn't do so. When your rig hits the ramp it will inevitably bottom out & the 1st parts to hit will get abraded down like ya put a belt sander on em. Your tires will have enough traction if you carry enough speed on the approach to the front. If you're accelerating hard or steering hard, for that matter, on the ramp it's too late already, just go around again. Just my opinion tho This has just been my experience w/ jumping, but try not to be hard on throttle when you land either. Tough on equipment- tires, diffs, driveline etc. Here's the 1st one I built, free dumpster build
