What are the advantages of tapered pistons for a basher? I know m2c made something similar. Opened my shocks after a year of use and i have been thinking about an upgrade
I just want better handling offroad in general. Seems facing down if i understood means a more reactive suspension on rough terrainTapered pistons have one tapered side. Mounted tapered side face UP onto the shaft makes for faster compression. Reversed facing Down, makes for faster compression strokes. Its your choice what benefits you best, faced up or down.
The Taper is rarely on both sides. Has no advantage or disadvantage.
Tapered pistons if the same hole size as the Original pistons, wont need an oil weight change necessarily. But that is subjective to how you want them.
Edited.
