Did you do it after a big jump/landing?
What's the other side like? Is there a lot of slop in your driveshafts/dogbones?
"Slop" in this instance basically means movement. You might say "slack" or "slackness" instead.Thanks for your help! What do you mean with slop? I am dutch and don’t understand this word?
Thank you that make sense with the added pictures and explanation. Perfect! I check if I can stiften up my springs and thinking of removing the washer do it’s a bit shorter."Slop" in this instance basically means movement. You might say "slack" or "slackness" instead.
Below are two pictures showing the slop/slack or free movement my driveshaft/dogbones used to have.
If they can go too much then you could possibly pop a driveshaft out when your suspension is at maximum travel.
Thank you! I think you are right. I took some pictures before fixing the problem and the ends where not tighten up.Did your pillow balls loosen up? I believe thats what happened to mine and the dog bone kept popping out. Used teflon tape and removed the camber shims...fixed it right up.
Also check the red pillow ball cap screws.
Fantastic my friend. They will most likely loosen up again and again. Keep an eye on them or take them out and wrap threads with a layer or two of teflon tape, then reinstall.Thank you that make sense with the added pictures and explanation. Perfect! I check if I can stiften up my springs and thinking of removing the washer do it’s a bit shorter.
You may also want to check the setting of your droop screws. They are near the inside of the a-arms, and control how far the arms travel when fully extended. When set properly, they stop the shocks from fully extending, and may help a bit with the dog bone issue. They are located in similar areas front and rear.Great tip? Thnx
It's just one more thing to help keep the suspension running at it's finest.Except dog bones usually pop when the arms are flexed up which the drool screws don’t help with
Got the tip from another member here. Passing the thanks to @Notorious J.Great tip? Thnx
