- ridgefield ct
- Limitless
- Kraton 8S
- Kraton 6s
- Kraton EXB
- Kraton 4s
- Talion
- Typhon 6s
Ya, 550 shipped.Wow!!! That’s a nasty set up!! Wish I had the coin for that!! Someone will def enjoy this
Would u consider selling the tx/rx seperately!?
Idk, maybe. I can go and measure itJust making sure, but that TP says 2022KV on the can and it has an 8mm shaft. Correct me if I'm wrong, but isn't that a 4080 and not the 4070?
Just trying to make sure you're assessing the sale price accurately, that's allIdk, maybe. I can go and measure it
Let me know. I may be interested. Is it sealed and M4x25 bolt pattern?Idk, maybe. I can go and measure it
I think you're right, that's a 4080cm motor, that's a bad mofo!! If this gets pieced out, I'd be interested in the xlx2 and 170sbl depending on the priceJust making sure, but that TP says 2022KV on the can and it has an 8mm shaft. Correct me if I'm wrong, but isn't that a 4080 and not the 4070?
Yessir it is, I have oneI think you're right, that's a 4080cm motor, that's a bad mofo!!
I’d do $300 shipped, both are new never used.I think you're right, that's a 4080cm motor, that's a bad mofo!! If this gets pieced out, I'd be interested in the xlx2 and 170sbl depending on the price
It isn’t sealed. But it is the m4 25Let me know. I may be interested. Is it sealed and M4x25 bolt pattern?
Kind of. It originally was going to, I wanted to build a beast of a boat. But decided not to.Is this all the stuff you took out of the roller you sold the other day?
Just responded!Now about for that
Dual 8s in series….I guess I never gave it all that much thought, but I can't recall ever seeing an 8s pack. Those fk'in things are ginormous.
Got me wondering if I need one in my life. Doing research...
GLWS
My bad. How much for just the motor?Kind of. It originally was going to, I wanted to build a beast of a boat. But decided not to.
Just responded!
Dual 8s in series….
Speed build….
I thought the same thing and then got to your post and saw I wasn't alone haha.Just making sure, but that TP says 2022KV on the can and it has an 8mm shaft. Correct me if I'm wrong, but isn't that a 4080 and not the 4070?
