PatMarcus172
- Solihull, United Kingdom
- BigRock 4x4
- Talion EXB
- Vorteks
Dear Experts
Well, tomorrow my daughter gets her Pink'n'purple Vorteks and as the complement to my Big Rock, Im obviously Im hopeful its gonna be amazing and that the QC out of the box is spot on.
But Im also a realist, so I thought Id make a list of things to check before we run it hard. Please help me with my compilation :
1. Mesh
2. Check the motor mount isnt bent out of the box
3. Check the pinion is on tightly and loctite if necessary (will try the speed pinion at a later date)
4. Slipper Clutch and then loctite it (as per Razor's video)
5. Check the diffs are full of oil and spinning smoothly - front and back
6. Loctite the drive shafts
7. Check the shocks are full of fluid and add some spacers at the front (how many??)
8. Check the wheel nuts are on tight
9. Steering end points and brake/acceleration setup
10. Check the tyre rubber to see if it needs glue-ing anywhere
Anything else ? I feel like there's more
1. Mesh
