iLikeRCs
Hi I got a new motor after the old one broke (a magnet inside split In half ??) and now I'm setting the gear Mesh. I want to ask if it is set correctly like this or not:
Yeah I did that. Put a lot of it on the pinion set screw and a drip on the motor screwsJust make sure you did use Blue TL on the pinion set screw and motor mount screws. Or your setting may drift.. Let TL cure for 24 hours. Or it wont stay tight if bashed right away.
I don’t think you could have set it better ??Hi I got a new motor after the old one broke (a magnet inside split In half ??) and now I'm setting the gear Mesh. I want to ask if it is set correctly like this or not:
