Typho1021
Hey all I got a question the GPM CVDs for the 4 x 4 3SBLX models do they need to be lubed?
They shouldnt but id do it any way prolong the life you got pics ?Hey all I got a question the GPM CVDs for the 4 x 4 3SBLX models do they need to be lubed?
Thats nice i can't wait for mine to come in im getting it in orange & a carpenter pencil ? For what & i use red and tack from lucas oil company they probably sell it at your local auto store & i have little babies so i use a old baby syringe and inject it in hard to get to spots so its not every where
You gota check the gear mesh (distance between the pinion and slipper clutch but i have a senton same shiit different body lol & mine does wheelies off 75% setting 100% it's almost doing standing backflips i have the integy steering bell crank & gpm diff yoke in the rear you got to let me know how those cvds hold upFor the CVD’s lol I use the same on diff gears.
Was breaking a set of stock per battery pack to the point that it wouldn’t allow me to use 100% setting. Turning was an issue too so I went to 30k in rear and tested. I like it won’t wheelie right off the line. I not a big jumper but I do play hard
Any brands or suggestions on the dry graphite @mxfan69Guys dry graphite or nothing at all on the open splined shafts of the GPM’s or be prepared to disassemble and thoroughly clean every single time you run in the dirt or sand. Any oil lube or grease is going to collect every piece of passing dirt and seize them up.
I use the red and tacky for everything or i soak bearings in wd40 for a couple hours & the yoke makes a big difference IMO more sturdy back end i only have it on the rear and it helps with like the sway when giving a full rip & stock differential it comes with metal planet gears inside the diff but the outside gear where the yoke is is plastic ive never opened my diff bieleve it or not and ive had my senton for like maybe 6 months i have insurance on my rc so when the diff goes i send it off to get replaced with a new one i got maybe a 2 month old rear diff in my sentonlol still need lube Suggs for the CVD’s some type of Graphite or something??
I have a HR yolks coming in to rebuild with the steel geared differential set, tired of going through the plastic pinions
How do u like the GPM yoke and how is ur diff built?
