KringelbertFishybuns
- Granite
- Kraton 6s
- Typhon 6s
Are there any upgraded options for the Granite Boost 4x2 motor mount, or a way to make the motor, or at least the screws that hold it more durable? I am now on my second motor with this problem because the screw holes keep loosening up, causing the screws to come out and the motor to shift around, losing the gearing. I drilled a new hole and even tried a tiny dab of Loctite on the screw tips in hopes that would help the screws hold. The car is by no means run hard in any way since it’s my younger son using on a 2S at 50% power, but it seems like every time he bumps into something, it knocks the motor off a little at a time until it just doesn’t run and I have to find a new way to make it stay put.
