AaronF
Just stripped out a spur gear unexpectedly and after some investigation it looks like the clutch may have been way too tight.
Found that the rear output side of the clutch assembly has a tiny crack and is out of round (#1), the bearing won't slide off now. Lower portion of the shaft measures 9.96 and where the bearing gets stuck is 10.05mm so something went wrong there.
I pulled the clutch apart and found that clutch material is worn excessively on #6 in the photo, with slight wearing on #2, all the other parts look new. #6 worn face interfaces with #7. The backs off all clutch material looks new (like in #4)
Could this have been the root cause? I crashed into a small wall square on at full speed which probably destroyed everything.
