SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
Trial and error what works for you. Try a middle compound to start. And what works on one rig for someone else, won't necessarily work on others or for you. Too many variables to consider, not just the compound. If you drive fairly well, you can adapt to whatever compound. But in general Compounds equate to the Temp of pavement surface you have. Not a hard rule however IMHO. Just as a guide.I want to get some GRP 1/8 slicks for speed runs. Not sure what compound would be better suited for it.
My thinking is softer for more grip but not sure if softer is right at speeds.
Info:
It's cold (9-18C) here atm and the road surface is coarse asphult but level. Running the Typhon 4x4 on 4s and choons but may go 6s soon. I'm only newish to speed, currently at 81mph, aiming for 100mph at the moment. Not sure how much more the choons can handle. (Anyone gone faster with choons?)
A know foams would be a better option but BSR and Gone Bananas are pricey here.
I've got the GRP compound chart but still not sure. What do you recommend?
Foams are a waste, very shortlived, and only needed for 140'ish -200+ MPH serious speed runs. Common to only get several good hard passes with Foams at those high speeds. They will start to chunk out fast. Been there.
Keep pushing the Choons for now. Legit Hoons are generally good for 120 to 130, so they say. If they are not abused/ bashed/drifted on hard. I never heard of any serious complaints with the Choons at Sub Triple digit speeds. Should handle your 100mph target PB.
Definitley go with some GRP's, to experiment with at some point. The popular brand these days.
