SilentSassin
- Thread starter
- #21
Okay I think I see what's going on, the Typhon actually has a different axle than all of the 3s line. The detta/infraction is the same ARA310995, the BR/Senton/Granite/Vortek is the same ARAC9443, but the Typhon is ARA310905 since it's the only one in the line that uses 17mm hex.I believe you would need the typhon cvd axles an axle stubs for those..I've tried the HR +10mm adapters an the cheap narrower ones on ebay..imo the cheap ones are better,lot less wobble..you could go to JENNYRC an see if those hexs only fit the bigger axles stubs.id just go with the cheap 18$ ones have worked great for me
I also found a video that Earl Moorhead did swapping over the detta body onto an infraction, and it really wasn't hard.
So going to do the 17mm conversion with the shorter axles, grp's, detta body, antenna mod for a little better reception, better 4s pack like a cnhl and see where that gets me. Even if I do decide to go with a castle esc and tp motor like you suggested, I would still need to get these things in place anyway, so won't be money down the drain.
