Hi all,
I beg for help. I have bought my Kraton V3 (2018 model) in February, took it out several times and now I've found out that the car is not steering properly. When put on the ground, Kraton steers front wheels only a little, and it makes screeching noise. When the front wheels are in the air, it steers fine. I disassembled and lubricated all the parts like ball pivots, linkages between servo horn and arm, the steering arms and so on. Every part goes smoothly without big resistance and no parts are damaged. But it helped only a little. I have also tightened the servo saver, but it did not help. Right now the Kraton on smooth surface makes 360 degree turn in approx. 5m radius, while when it was new, he turned in about 2,5m circle. The servo has enough power and I believe despite some bash crashes it is working well. Now it is difficult and annoying to drive it.
I am very unhappy from this, because it is my first RC (I decided between Kraton and E-Revo). And few first rides were just great! I run on 4s only. Please tell me, what more can I check, tighten, or repair. I chose the Arrma because it is supposed to be built tough, but this is really disappointment. Thanks to all for any advice.
