Oh. Yeah looking at the description in the link you showed it says motor shaft and those are usually pretty stout so. You could probably make 4 pins if you just bought one pair of those pins.Already ordered. Hopefully it works
Heavy duty reinforced cut off wheel for the dremel would be what I would try.Yup. 4 pins. Just not sure how I'm gonna cut it. Bolt cutter should do it but then the end gonna get crushed.
I can't believe I posted that and they sold out that fast!! Wow. I guess I ordered the last set. It's nice to always keep spare pins. If you make your own just make sure not to bevel the end to much. I did that when I made pins for my rc18 and it aventually started lobeing out the control arm side after the knuckle and made the wheel super sloppy.Exactly out of stock
Yea, but has anyone tried it? The pins are out of stock everywhere
