Hot Racing rear diff after 1 year of use.
Crash
Saturn
Kraton
This is my hot racing rear differential after one year of use. I did replace the bearings and put a different weight of oil in it about 6 months ago but still have no leaks and all the screws are still tight. Other than wiping it down with a rag this is how it came out.
joostin420
MA/NH
Fazon, Kraton, Outcast, Senton
They are definitely a great upgrade for all 3x diffs ;)
Crash
Saturn
Kraton
Yep! By far my favorite upgrade. The Hot Racing center diff is such a great upgrade due to using loc tite and temps.
olds97_lss
ArrmaForum Fan
How's the wear/slop on the output shaft that comes out of the cup? Wondering if the aluminum is wearing more than the steel insert in the stock cup.
Crash
Saturn
Kraton
Its good! Its still smooth and with no movement. When I build my diffs they're pretty snug because of the shims. I make sure they're tight even a little notchy because they will loosen up after a while which kinda goes against conventional thinking that they should be smooth at the time of the build.
Similar threads
