How do I set gear mesh?
Wisconsin
  1. Felony
  2. Mojave EXB
  3. Talion
  4. Talion EXB
My front pinion an ring gear mesh makes more meshing noise then rear diff. Teeth are not chipped or broken,side shimming doesn't help. Side shimming in rear diff make it louder there so I removed them. Trying to get ring an pinion mesh a little less clicking clacking sounding. ( Have HR diff cups in front an back?)
I reckon this might b what's leaving a mark on your HR diff cup ?? Maybe ?
Pinion didn't move,is still tight. HR diff cup .005 larger dia. HR doesn't allow for oxidation correctly. Have found some other of there's to be the case.
Ahh so the powder coat on the outside makes it bigger. I've never had much trouble with front and rear diffs it's allways been the center one. Since I have installed the HR center diff I've had no fluid leaks. The stock kept leaking and blowing the stainless insert. Happy days !!
