Jluther@becoinc
- Senton 6s
- Talion
Big felony hoons v2V1 or v2 infraction and are you running hoons or GRPs?
For what it’s worth, I plugged your setup into a gearing calculator app I purchased. Here’s what I got.I have an Infraction that I have installed a HW 4985 1650kv with Max6 running 8s power. I’m also running a 40 tooth spur with 25 tooth pinion. What kind of speed do you all think I should be able to get with this set up? Thanks for your time and help?
Absolute top you can expect with great lipos and a perfect pass 127mph. In reality, as @Mr.Duke said, probably 10mph less than this perfect world scenario, my guess is 112-117mphI have an Infraction that I have installed a HW 4985 1650kv with Max6 running 8s power. I’m also running a 40 tooth spur with 25 tooth pinion. What kind of speed do you all think I should be able to get with this set up? Thanks for your time and help?
Thanks guys. I ran it yesterday and it said on my gps which has taken some serious abuse 85 but I don’t trust it it has never read anything above 85 and I’ve hit that 85 a lot and when I can tell the runs are way different. I think I am hitting some kind of cut out point too. Would a cap pack help with that? Thanks again!Absolute top you can expect with great lipos and a perfect pass 127mph. In reality, as @Mr.Duke said, probably 10mph less than this perfect world scenario, my guess is 112-117mph
Slower throttle input is probably the thing you need to work on. Can't floor it like a drag car. You should only be wide open for the last second of your run.Thanks guys. I ran it yesterday and it said on my gps which has taken some serious abuse 85 but I don’t trust it it has never read anything above 85 and I’ve hit that 85 a lot and when I can tell the runs are way different. I think I am hitting some kind of cut out point too. Would a cap pack help with that? Thanks again!
