I googled this for awhile looking for a solution and didn't see much. Posting this incase someone else is looking too.
I just got some new Backflip LP tires and wanted to wrap them with braided line. My initial plan when looking at pictures was to dremel a slot in the lugs indicated below and wrap it there.
Then I saw this video from @Bournemouth RC and decided to thread them through the same lug.
I made one modification to his method. I pulled the thread through the needle so I had 2 equal pieces hanging from the needle and long enough to go around the tire twice plus some spare. So I was effectively doing 2 wraps each time I went around. Went around twice for a total of 4 wraps, tied 2 knots, glued it and repeated on the other side of the tire. It looks like 2 wraps, but if you look close there's actually 2 lines really close to each other because they get pulled tight together.
Took it out yesterday and saw little to no ballooning. I'll probably do a video on the stand later today to show the real world effect.
