Sgt_Nutcase
Hey there my rc car gets a little toasty so i was wondering how many fans can 1 port from an stx2 receiver power?
Im running 4s if that helps.
I'm running an esc fan, two fans on the motor and an edf for added flow in the cabin without issues. No noticeable difference in run times eitherTypical fans (.1 to .2A) you are probably ok up to 1A or 5 to 10 fans. You would have to check on more powerful fans.
What motor are you running the EDF on? Brushed?I'm running an esc fan, two fans on the motor and an edf for added flow in the cabin without issues. No noticeable difference in run times either
EDIT: forgot to add, the edf has a 12 volt motor but even at around half voltage it spews air like a teen who just got drunk for the first time vomits...
Yeah, it's a brushed motor, something I had in a drawer from years agoWhat motor are you running the EDF on? Brushed?
Please can you post or pm a few detailed pics... thats getting creative juices flowing. Whats the fluffy guard made from?!Yeah, it's a brushed motor, something I had in a drawer from years ago
Which 12v fan do you have? I run Surpass Rocket fans (28.000rpm) on 8.4v and they move some serious air; making the Hobbywing 6v fan look like a complete beginner fan. I like to play and test things, so am interested in a ever more powerful fan.What current draw do you have on the EDF? I'd think that would be a little too much for your ESC assuming you have strong servo.
Keep in mind that main current from the ESC/BEC goes to the servo, the difference between max BEX current and servo draw is what you have available Servos suck quite a bit.
You could switch to 12V fans in general, I just did that and run them on 7.4V. Easily twice the airflow of the 'turbo' stuff and a lot more resilient.
The padding is just packing foam sheet I cut up from one of my Amazon shipments. Held on by zip ties, easiest way without modifying the model itself. I got the screen from a small strainer to keep out rocks. The whole thing is held together with some shoe goo...Please can you post or pm a few detailed pics... thats getting creative juices flowing. Whats the fluffy guard made from?!
I don't know, whatever the stock esc puts out on the Kraton. Been running it for a month without issueWhat current draw do you have on the EDF? I'd think that would be a little too much for your ESC assuming you have strong servo.
Love itThe padding is just packing foam sheet I cut up from one of my Amazon shipments. Held on by zip ties, easiest way without modifying the model itself. I got the screen from a small strainer to keep out rocks. The whole thing is held together with some shoe goo...
The fans on the motor are what came with the heatsync and the esc fan is what came with that. I don't know what manufacturer made the edf I am using as I bought it over 6 years ago
It makes a HUGE difference. My temps went from around 200°f to around 140ish just adding the edf during the 100+ temps we were having in Texas. The body seals up surprisingly well keeping all that heat trapped inside. Now, with the edf, it's blown out the backIf it ain't broken don't fix it i.. if it works leave it be
Your servo (same as mine) is in the 4A range and stock ESC can sustain 5A.
Does this EDF actually help or does it just sound cool?
It's a good idea if you are running a dusty cover or closed body to get some air in.
If you're using electronics fans they are not designed to pump out air at lower voltages. You have to look for brushed fans. They'll provide more thrust even at lower voltages...or get yourself a two inch edf. That sucker still pumps out air at whatever the receiver is giving itWow, that EDF is impressive!
I have access to an abundance of 12V fans at work, and I found that they run very slow on the 6V(?) that the receiver and/or stock BLX ESC puts out.
Maybe this is crazy, but I made a bunch of harnesses to run the fans directly off the battery balance leads. Since there is no fusing, I added a 0.5A fuse to protect the batteries from some catastrophic event if the fan were to stall and short out.
