I am struggling a few days with the following issue, I hope someone can send me in the right direction I tried many options already.
The car is an Outcast 6S BLX (EXB) from 2021.
I bought 2 of those cars one for my daughter and one for me. Both have the same issue.
The original issue is that the steering has way too much under steer. The reason for that is the weak servo saver (non adjustable) so I did the modification you can find on internet. The modification is adding rings to the saver so the spring is more compressed, all went fine.
Now that the servo saver is stronger and no deal breaker anymore I bought a stronger servo, that's fine also.
For the horn I bought the Hot racing aluminum fixed link from USA and it fits perfectly. I also have other horn combinations but the problem is not in the connection, so all connections are fine and optimal.
Here comes the problem!
The angle range from the servo's (both stock and new) is not enough to get the full throw left and right. When I put the horn on its fine one way and not the other. When I change 1 teeth its fine the other way around. The conclusion is that the total range (degrees) from the transmitter (DX3) cannot cover the whole mechanical range the steering need.
I hope I explained it well like this. My question is there another transmitter that can bring a wider range in degrees on the servo. Then I can adjust the endpoints.
Now The endpoints are not needed because the server hardly gets to the endpoints.
